- bagmanExplorerLots a good information here! Bagman.
- BigSkyBobExplorer
ratfink09 wrote:
I use a water deionizer from Griots Garage. Wash and rinse your RV with the deionized water and walk away. No water spots. A little pricey but my back thanks me! Works great on house windows too.
I use a similar system, flawless. - ratfink09ExplorerI use a water deionizer from Griots Garage. Wash and rinse your RV with the deionized water and walk away. No water spots. A little pricey but my back thanks me! Works great on house windows too.
- BumpyroadExplorerHey, it was "as seen on TV" so it has gotta be true.
I see that they say Reaches up to 27' high with 60 PSI of home water pressure (Lower PSI will result in less distance)
but $50 for a $10 sprayer and a few ounces of surfactant??????????
bumpy - TinstarExplorerI was curious about using on my RV too. I read the reviews on Amazon about it on an RV. Terrible reviews. The RV use reviews (two or three of them) said their RV looked worse after using it than it did before. Hope it works for you and I'd like to know how it worked out for you after you use it.
- chuckftboyExplorerDo yourself a favor. If you want to clean your coach, get a foam cannon and soap from Chemical Guys and foam the dirt off. Its really safe for your paint.
- BumpyroadExplorer
Treefrog wrote:
. . . and how did it work?
I shall report back after I use it.
bumpy - TreefrogExplorer. . . and how did it work?
- BumpyroadExplorerisn't it a foaming cleanser. just bought a gallon of this for about $5.00 at pep boys.
bumpy
