RCMAN46
Nov 04, 2013Explorer
Did a little research. It was difficult to find a torque curve for the Ford V10. I found some data and made a curve on Excel.
The V10 is anything but flat on its torque curve.
Also found some curves on Chevy engines. If you look at the never Chevy they have torque curves that are very flat. Some better than the V10.
Chevy Curves
Looking at the V 10 if the op was at or near 3400 rpm then the downshift may have put him on a lower hp portion of the curve when the engine went to 4400 rpm. Not knowing what transmission he has for sure or even what the gear change was this can not be determined for sure.
The V10 drops off very bad above 4000 rpm.
Chevy Curves
38,782 PostsLatest Activity: Aug 11, 2021
