It's mechanical. If it were a safety issue all the manufacturs would state the same. It's about proper lubrication and heat. IMHO its how they disconnect from the engine and trans. If there is anything left spinning, not getting proper lubrication and cooling then there is a heat building up and friction on gears and bearings that aren't lubed as they should.
Why people wish to dispute the printed material provided by the manufactures regarding this is scary. I guess it's the same reason we hear some people drive 75 -80 mph or more knowing there is a speed rating on their tires. Sooner or later it'll catch up to you.
If you value your cars warranty then you'll follow the instruction manual provided to you. Or there are other choices in vehicles that would be a better selection.
