rgatijnet1
Oct 28, 2014Explorer III
If you go with the RV specific DynaBeads, they are a little larger and DO NOT require any special valve stem and are compatible with any TPMS.
The DynaBeads also continuously balance your tires as you drive, even when the rubber is wearing down or if your rims pick up a little mud. The DynaBeads come in bags that are easily installed, unaffected by moisture, and even make it possible for you to balance your unmounted spare tire when it is installed in an emergency.
I do not like the balancing powder because it is too susceptible to clumping if there is any moisture present. The Beads eliminate this problem.
38,769 PostsLatest Activity: Jul 09, 2020
