rgatijnet1
Oct 28, 2014Explorer III
Just make sure that you are not confusing RV specific beads with other beads or with Equal powder. The powder will cause vibration if they clump, which is very common. Beads should not need to be vacuumed out since they will just roll out if the tire is tipped. In fact the beads can be reused in another tire if you want to be cost conscious. I read on here about people confusing the different products all of the time. Even in this post some talk about the beads needing a different valve core. If you use the correct RV SPECIFIC product, which most truck type tire dealers do NOT stock, you do not need to change the valve core and you do not have to worry about vibration unless the tire is out of round to begin with.
You also have to make sure that you use the correct size bag to throw in to the tire when it is mounted.
I ordered my own DynaBeads and just gave them to the installer when the tires were mounted. Click on the link below and scroll down to the RV and Motorhomes section.
DynaBeads
DynaBeads
38,769 PostsLatest Activity: Jul 09, 2020
