usersmanual
Oct 26, 2016Explorer
want-a-be wrote:usersmanual wrote:fwant-a-be wrote:
To test the pump we poured water in the washer and put the drain hose in a bucket, the pump works fine. Don't know where the pressure switch is located. Was hoping to come up with a fix before I have to remove the unit. Also as I have said the washer will go thru some of the cycles before we get the F11 code.
well I gave you the repair manual it should be of some help- as I said the F11 code says possible bad pressure switch and it does say it controls overflow? you want a fix? I feel this idea is as good as it gets for now?
its also possible the control board is gone bad But I would change the pressure switch first(much cheaper)
Sorry about the manual I did not see it
Thanks
just sent u the parts breakdown also shows part numbers etc
also as said maybe a bad control board and not advancing correctly.I have seen that before also
38,780 PostsLatest Activity: Aug 05, 2026
