WILDEBILL308 wrote:
FIRE UP wrote:
Well Gang,
Yep, I have to agree with the "Push on" type. The Freightliner chassis under my coach is loaded with them. Now, I will admit that about 99.9% of them are at solenoids or mounted fittings of some sort but, non used for "Splicing". But, if I had to do what the OP had to do, I'd use the push on/in type all day long. In fact, I plan on adding a short line to the shrader valve on the bottom of my coach and run it to just inside a nearby compartment.
My coach looses about 10 lbs. of air a day, while parked in it's home, next to our home. Every once in a while, I have to crawl under it and feed it some air, to bring it back up to normal height. So, I'm planning on using those push-in/on types when I construct this little addition.
Scott
Why do you feel you have to add air? Just dump the air and leave it it will set on the stops till you start it and get ready for the road. Why do you crawl under to add air? there should be a air chuck in the front above the generator that the wrecker hooks into your airline to release the parking brake so it can be towed.
Bill
Bill,
Well Sir, without hijacking this thread about the OPs question of splicing air lines, I'll briefly explain why I do what I do. You see, we park our coach indoors, inside an RV garage which, is attached to the two-car garage. It's a brand new home. Because this coach does loose air, it will over a week or two, loose almost all the air. Now, you and I and just about every one else who has a diesel coach, knows that low air means the brakes are set and, you cannot release them until a proper amount of air is built up in the system.
So, what that means is, the upon start up after sitting for a couple of weeks, the engine needs to run for quite a few minutes prior to the ability to release the brakes so, I can move it outside the RV garage. And, what that means is, I'm filling the inside of that RV garage and the two car garage next to it, with diesel smoke and all that smell.
I only let that rig sit about two weeks maximum without starting it and moving it outside so I can mop and clean the floors of both garages.
But, if I know I'm going to move it out side and, the air system is really low, I creep under it, remove the cap to the shrader valve and fill the system enough so that I can start the rig, immediately release the brakes and, move it outside without running it too much indoors.
Now, as for your statement about "there should be an air chuck up front", you are correct. But, I'm not going to say you're wrong in what you say, I'm only going to say what "I" have to do to fill that air system if, it drops waaaaaay down to say, oh around 20 lbs. or so. You see, if that system drops below 65 lbs., there's a check valve some place that prevents filling it, (at least on my coach) by using that air chuck in the front of the coach. I know because I've tried it several times. It will NOT fill when it's that low.
But, if I crawl under it and, use the shrader valve on the base of the air drier, it will allow me to fill the system completely or, I can fill the system to somewhere "over" 65 lbs. and, then, I can go up front and utilize that air chuck you mentioned, and finish filling the system to 120-130.
Now, again, I don't know if or, how different my air system is from anyone elses but, I've proved that method, several times. I've lowered the air pressure by pumping the brakes, 'till they set themselves. Then I've tried to fill the system using that front air chuck, NOPE ain't happening. And, to prove my point here, a buddy's Vectra of the same model year, '04, with the same engine, a C-7 CAT, died and wouldn't start while camping in the Sierra Nevada mountains.
A wrecker came to tow it to a diesel shop to get it to run. I was not there, at the time. The driver of the Wrecker, attempted to fill the air system via the front air chuck. He couldn't fill the system enough to release the brakes. He apparently did not know about the one on the air dryer. He tried several times.
Anyway, that's why I do what I do.
Scott
" A better question is why do you lose 10 lbs of pressure a day? Mine rig often sits for 3 weeks at a time and I have no noticeable ride height change and very little (if any) pressure loss on the gauges. Rather than adding a fill connection, I would look for a leak with soapy water and fix that. Good luck."
Lou,
I most certainly agree with you on, search for the air leak and fix it. I spent most of my career under fire trucks, (as well as driving them and operating them) doing things like searching for air leaks, water leaks, oil leaks, and more. It's a pains taking operation to try and follow every inch of air line(s) from front to back, up and over axles, Omni-directional around valves, fittings, around wire looms, and much, much more, in search of an air leak.
It is good that yours is more sealed then mine is. I envy that. But, mine is what it is. Maybe some day I'll finish ALL of my projects and then, climb under that coach, and start searching for the leak. It may be that I'll find it in 10 minutes, or, I could be under there for days, who knows? But, in the mean time, based on the explanation above to Bill, if I take a 1/2 day, create that little air line, from the shrader on the air dryer to an accessible compartment, only a couple of feet away, I can fill that system without getting under the coach. And, so can a wrecker, if and when the need ever arises and he has to fill it. Hope this explains why I do what I do.
Scott
Sorry to the OP, certainly did not mean to hijack the thread with my explanations.
Scott
