mlts22
May 01, 2014Explorer II
The higher clearance will make it easier to fit a PowerTech genset right in front of the hitch. That way, you can have 3000 watts of diesel and the generator will be well out of the way of the departure angle, and by adding a skid wheel to the tow hitch, if the angle isn't enough, the hitch will take the pummeling, not the generator case.
Just FYI, May 5 is when the initial orders for 2015 Sprinters are being taken, and they will be here in October for 2WD, 4WD models likely in December or January of 2015.
The rear heater prep is interesting, especially when used with the Espar MCS 16, because on shore power, you still get on-demand hot water and warm air. On the road, the engine coolant provides that. I don't see it offered by Sportsmobile, but it would be an interesting thing to have.
38,768 PostsLatest Activity: Jan 26, 2021
