CoeyCoey
Feb 04, 2019Explorer
rjstractor wrote:
I don't know how big you need or what your price range but here's a Gemini based on the Ford Transit with either diesel or gas. Add a Quigley 4x4 conversion and you're at around $100,000. I don't know if you are 100% set on a Sprinter, but the Transit is pretty comparable other than a 700 lb lower GVWR.
Thanks for the idea. I did check them out, but none of their floor plans work. I am looking for something where the bed is usable with the slides in. I do a lot of long distance traveling and I often stay the night in rest stops, or off highway exits and wouldn't be able to extend the slide for sleeping.
If I went with a new RV, are there any manufacturers that make Class C's from a cutaway? If I ordered a Sprinter 3500 4x4, will anyone turn it into a class C? This would likely be about similar in cost to getting a conversion done I suspect. Plus, I would get all the options I wanted in the Sprinter, and could delete the options in the RV I will never use. Resale would be very good as well.
38,782 PostsLatest Activity: Sep 19, 2026
