ron_dittmer
Sep 01, 2016Explorer III
pnichols wrote:I really do understand your point.ron.dittmer wrote:Ron,
I had while-you-drive-adjustable air bags in my first motor home. What I learned from them was...the more air I put in them, the harsher the ride was...period.
I've read in these forums of others having the same experience of a stiffer ride after adding air bags.
I suspect that this is due to the air support of the air bags being ADDED to the existing steel support of the rear springs. What needs to be done is to SUBSTITUTE some air bag support for some steel spring support.
This is in fact what is provided by a full air suspension system - the entire weight of the vehicle is supported at the proper height entirely by the soft sponginess of air - with no harsh steel spring support present at all.
What I'm suggesting is a cost effective way to add some air support at the cost of some steel support. This would be less expensive than completely replacing an existing steel spring system with an air suspension system.
My particular rig sort-of falls within your recommendation. You say to remove springs to make the suspension deficient, then supplement with airbags to increase the ratio of air suspension to spring suspension. My rear suspension is slightly deficient when fully loaded up, but I can't imagine airbags for my situation will soften the ride. Maybe if I removed more springs like you suggest, I could notice an improvement in the quality of the ride. But I am not comfortable relying so heavily on air bags to prevent the rig from dragging on the street.
There was a time I contemplated adding those Firestone rear air bags to see if I could lift the rear a little more to level it when fully loaded. But anticipating a rougher ride had me dropping the idea. The sag I have is not enough to take action over.
Thanks for your thoughts on all this.
