DustyRooster's avatar
DustyRooster
SS TracBar Install (F53)
Hi all!
I will be installing a SS401 tracbar on my F53 chassis.
Hoping one of you could help me determine whether or not I need the RV levelers down before the install?
With the levelers down, the RV is "level" but does that also mean the frame/diff is the most level as well, or should I drop the levelers and install?
Any help or insight would be much appreciated.
Thanks!
  • Good Morning!
    Just wanted to provide an update. Track bar install was easy peasy! I did keep the levelers down, and once installed I dropped the RV and tightened everything up. Just finished my first leg of the trip and I cannot believe the difference the Track Bar made. 80-90% of the dreaded "semi push" was eliminated! So happy about the purchase! Now onto an anti sway bar to help reduce the crosswinds!
    Thanks again everyone for the input and advice!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Do you need the levelers down before the install: NO
    You do however need to be on level ground or very close to it.
    When installing a track bar the RV should be as close to "Going down the road" as it gets.
  • When I had that chassis under my motorhome at that time, I had the jacks down to crawl under and loosely install the track bar. Then once it was basicly on, raised the jacks and then tightened it all down. Made a HUGE difference in how secure the MH drove when pulling my car. Was a good investment for me, hope youy like it too.
  • Thanks for the feedback! Much appreciated!
    I am not too far off level in my garage, but I will put the slides in and raise the levelers before the install to basically mimic the way the motorhome when cruising down the road.
    Thanks again!
  • As needed to fit the bar. Might add a floor jack would be used also or a bottle jack as needed.
