klutchdust wrote:
The curb roll on my 30' Cambria was minimized by the addition/changing of the shocks to Koni vs. what Ford installed on the chassis. Curious to see what the Sumo can do. Was under the impression they were meant to be more of a weight bearing device.
They're a constant contact compressible bump stop between the suspension and frame, is how I would describe them.
At least the ones I'm trying are. I have added the yellow rears (1400lbs combined support at 50% compression) SSR-338-54, and so far, they have done what they promised. I'm seeing reduced push/sway due to cross winds/big truck bow wash, and I used to bottom out the tail, if I left/entered my driveway a little too fast. That hasn't happened either.
I was impressed enough that I ordered the fronts SSF-106-47 (1000lbs at 50% compression) hoping to add some more stability to cornering and curb roll. Even a bit of improvement will be worth it. Still waiting for them to arrive.
My factory shocks are Bilsteins, and I haven't read anywhere that changing them out was worth the effort/cost, so I'm waiting to see if the Sumos alone will give me enough improvement.
