wildmanbaker wrote:
Jim, the scissor jacks may not be the answer. Ask anyone that has had them on a TT, the back end still moved around quite a bit. There is a lot of movement in them, especially when extended as far as you will need them. Bottle jacks are the cheap answer. If you are at all handy, you may be able to fab some right triangle braces to bolt the frame and extend out to the side of the MH, if there is room, to place the jacks under to easily use the jacks, without having to crawl under to install and retrieve the jacks every time you need them.
I hadn't thought of the movement with the scissor jacks nearly fully extended - thanks!
It's sounding more and more like a combination of jackstands and hydraulic jacks is the answer. I can get the rear close to level and then let some air out of the bags to drop them onto the jackstands. I can use hydraulic jacks on the front.
I'd be willing to drop $2k on a hydraulic system max, but I don't see kits that are anywhere near that cheap. There is a guy on eBay selling a kit he cobbled together for $1,200 but I'm wary of that and it's only 2 jacks.
