mussfly's avatar
mussfly
stabilizers while parked
getting tired of the rock while one is sleeping and another person is moving around. so i want to add stabilizers at the rear but i am posting this because i want to find out what is the best method to do this. such as a t type or a scissor type?
or is there a better way?
  • did anyone use this type to stabilize .http://www.campingworld.com/shopping/item/universal-rv-stabilizer/34337
    what is your thoughts and are they worth the money?
  • I installed a couple of scissor jacks behind the fuel tank, making sure that when folded they did not touch the black water tank and when fully down the screws did not meet each other, buy the biggest ones that you can, some times you need the height when camping in National Parks.
    I brought two pairs, installed two permanently and the other two I use up front when we are staying longer, I also carry a smaller scissor jack that I place close to the door to avoid rocking the RV when going in and out I carry them in the toad.
    Do not weld the jacks to the frame, drill holes and use bolts if one jack gets bent it can be replaced easy.
    navegator
  • There are a few approaches as you have indicated.
    Scissor jacks are more popular with trailers. They are typically bolted on the frame. A cordless drill is used to quickly lower and raise them. Be certain, when folded up they don't hang down in a way that they could get caught scraping when exiting gas stations and such.
    The tripod type are mobile, more adaptable & stable but do not self-store.
    Here are your low cost choices at a glance.
    Hydraulic jacks are ideal but are costly. They get fussy with age, weigh a lot, and also add technical complexity with wiring about the rig along with the controller by the driver.
    One more consideration.
    If your rig rocks and rolls when walking around inside it, What is it doing when you are driving it? Heavy duty front and rear stabilizer bars are very effective at reducing motion of both kinds. They won't offer rock-solid stability when parked, but may be enough as they are for us with our 24 foot B+ on an E350 chassis.
