DrewE wrote:
camperdave wrote:
I did install A Levelmate Pro though, which tells you exactly how many inches each wheel needs to be raised. I really like it, level first shot every time
When I first got my class C, I used some math to make a little leveling ruler calibrated in the number of ramps (2x wooden ones, in my case) needed to achieve leveling, one side for left-to-right leveling and the other for front-to-back leveling. I'd take my level and special ruler, set the level on the floor, and lift whichever end was low and measure how many ramps were needed. It worked very nicely indeed.
Pretty soon, I was able to eyeball the distance from the raised level end and didn't really need the ruler. Not long after that the level got lost and was replaced with one that's a different length, which of course throws the ruler calibration all off, and I haven't made a new one.
one cool thing about the Levelmate is you can turn it on when driving (it displays on a phone). Meaning it will give you real-time level info as you slowly drive around the Walmart looking for the most level spot.
My buttometer is not yet as finely calibrated as yours. :B
