southernkilowat
Mar 07, 2015Explorer
It is a 3M protective film, factory installed and what you are seeing is dirt/mold/mildew between it and the factory paint. It does come off, but is a BEAR to remove. My good friend had it on his, he spent several hours a day with plastic razor blades slowly peeling it off and it took him over a week. We tried goof off, and several other chemicals to no avail. I do know that the warmer it is, the easier it is to remove. He parked facing the sun and worked on it in the heat of the day. You could try a hair dryer, but I wouldn't recommend anything hotter like a heat gun.
Good Luck
Good Luck
