sdianel_-acct_c
Mar 08, 2015Explorer
WE removed ours but would NEVER do it again. We still had to pay someone to remove the last 18" strip at the bottom and have the front repainted. If you decide to remove it yourself: Get a heat gun and some plastic razor blades with holder or we used some plastic paint scrapers. Do not use heat gun on high setting! Use the heat gun to soften the plastic outer coat. Then scrape (carefully so you don't gouge the paint underneath) the outer plastic coat off. Once you have that done (2-3 days all day and sore fingers, hands and arms!) then get Goo Gone from Home Depot, Dollar General etc. You will need 4-5 bottles. Spray the Goo Gone on the adhesive and rub, rub, rub until adhesive is off. Unfortunately no easy way to do it. We decided that we would have paid the $1100 quoted to have someone else do the job!! I would never have that stuff put on another vehicle we own!!
38,782 PostsLatest Activity: Sep 10, 2026
