ScottG wrote:
midnightsadie wrote:
lets start at the source. take cables off battery and clean battery and cable ends, might even have the battery load tested, but sounds like your not geting good contact on the electric side.
Here is your answer. This is the first step and if you don't do this then you'll pay who ever fixes to do so.
+1
Had a similar problem with a Chevy pickup truck.
After putting in a new starter......I discovered that the real problem was the "neutral safety switch".
When you notice the problem.....WITHOUT turning it OFF.....move the gear shifter to N and see what happens.
