1995brave
Dec 06, 2013Nomad
sjholt wrote:
I think the problem is in the fuel pump relay system.
When you first turn it on the pump pressurizes and then when the main relay is suppose to run the pump it doesn't.
Check you fuel pump relays.
Nope! The fuel pump runs with the oil pressure switch. The relay is only used when starting, when oil pressure builds it closes the oil pressure switch and runs until the ignition switch is turned off or you lose oil pressure.
38,782 PostsLatest Activity: Sep 10, 2026
