No, it is not normal to have to input steering corrections all of the time but driving a Class A is different from a pick up truck. Naturally the road surface can affect your steering but after 500 miles you should have experienced different road surfaces. Wheel alignment is something that should be checked as well as tire pressure to make sure that all tires are balanced. They do make a steering stabilizer that is helpful to some drivers. It looks like a shock absorber mounted sideways to to your tie rod and is adjusted to keep your coach going straight on a flat road surface.
The cheapest thing to check is your tire pressure and then I would check wheel alignment. Four wheel thrust alignment is the best, if the shop is equipped to do it. This insures that your rear axle is pushing straight to your front axle.
After all of that is checked and eliminated as a problem, you will still find that the Class A drives different than your 5th. You should be able to relax behind the wheel, however.
