Bea_PAExplorerMay 18, 2016Steering play in E350We have a 2012 24V on a 2011 chassis. We have a lot of wandering and steering seems loose. The unit has 14,000 miles on it. Is this a known problem with this chassis? Anyone had this issue?Show More
HarvardExplorerMay 19, 2016Beware of the "tweak the toe, you are good to go!" alignment.The vehicle will need different Camber and Caster adjustment bushings such as Ingalls 594 concentric bushings to get the extra 2 degrees of caster.Explain to the alignment shop up front that you expect to get more caster from their alignment.
Related ContentPlay in steering wheelPlay in steering wheel = nerve wracking!Slack/Play in Steering92 Ford E350 steering problemsPlay/Slack in Steering
