MURPHY55347 wrote:
I don't want to get hung up on the aspects of a good alignment. I know about the cheap handling fix, sway bars, track bars weighing the coach and proper tire inflation. What I am trying to fix is the inherent sloppy on center feel of the steering wheel that seems to be present on all F53 chassis. That's why I would like to limit this conversation to steering stabilizers and if people feel it has any impact on the sloppiness and what type work best.
So, are you saying that all of those items mentioned have been checked and/or adjusted on your coach? Because many of them can cause the problem you want to correct. Most steering stabilizers have some sort of spring arrangement to bring the steering back to center if it is moved off. They may, or may not help your particular issue.
