Ivylog
Aug 21, 2019Explorer III
Guess you should have searched a little more as all that’s necessary to center is to remove the steering wheel shaft from the U joint at the base of the steering column (inside the MH)...takes all of 6-8 minutes. It’s a 10mm bolt holding the shaft in.
38,782 PostsLatest Activity: Sep 10, 2026
