So many misinformed posts.
Ford has only a single adjustment for setting the toe so it's likely the steering wheel will need to be re-centered after an alignment. Be sure to mark the original position before removing the steering wheel. There is no master spline so the wheel can be reinstalled in any position. You'll probably only need to move it 1 spline or possibly 2 at the most. The splines are on 4.5 degree centers so if your wheel is off less than that amount it will be off center slightly in the opposite direction when you reposition it..
Richard
