Dutch_12078 wrote:
usersmanual wrote:
T bone wrote:
On my new Ford motorhome the steering wheel is not straight when going straight down the road..The front end seems to be in alignment, no pulling or off tracking. Wondering if I could pull the steering wheel and just move it a little.
NO NO NO take it back to dealer and have it fixed under the warrenty it should have
Most likely the steering shaft has to be changed a couple splines as long as it does not have a master spline
My sparton chassis steering centered is done this way also
Read the previous few posts... On the 2007 and earlier F3's, moving the steering wheel on the shaft spline IS the correct way to adjust the steering wheel centering. On 2008's up there is a master spline for the steering wheel, and the adjustment is made by moving the pitman arm on the steering gearbox splines.
HEY Dutch_12078
I guess maybe its you should read previous posts instead lol
no big deal
quote:Sorry about that. I should have been more specific about the shaft that needs to be repositioned. It is indeed the shaft that goes from the steering gear box to the steering wheel.
