TomandCandyExplorerMar 24, 2019steering worked then acted like no power steeringGot home put motorhome over pit checked it out fluid everywhere easy right most likley hose leaking it sprayed good enough to spray fluid up under the gen gas tank ok cleaned every thing up added flu...Show More
grumpy3bExplorerMar 24, 2019Leak,I dunno but a reminder did you check the belt too? I overlooked that solution a while back,sooooo???
Related ContentSteering wobble.Safety steerSteering stabilizersSteering stabilizerAftermarket heated steering wheel?
