donn0128
Mar 09, 2017Explorer II
Is it a direct pull or cable pull?
Either way probably the best solution is take it apart using a generous amount of plumbers grease grease the blade and seals and reinstall it. If it is cable operated, while apart wipe down the cable and generously lube it with silicone spray lube.
