rockhillmanor wrote:
rr2254545 wrote:
They make a winch to hoist them but they are very heavy even with it - we do not use covers here in Minnesota because they do more damage than the weather with all the rubbing etc
In the outdoor facility I am In NO motor home has a cover - and there a total of 300 assorted RV's in it
X2
If there is any possibility of windy weather where you are parking it I wouldn't use the cover. It does cause more damage from the constant rubbing on the corners and paint.
I am originally from the Midwest where you would think all RV owners would use the covers and no one does.
You alternative is to look for an inside storage unit or ask the place you are at if you can have a metal/tarp carport over your MH. They are not that expensive and are easily put up and removed.
Metal RV carports around a couple thousand dollars.
Tarp RV carports around a couple hundred dollars.
http://www.shelterlogic.com/#garages-shelters
I got quotes for a 42' X 14' aluminum carport and they were right around $4000. One was slightly under and one slightly over.
