gatorcq
Mar 14, 2015Explorer
Your choice, another option is this:
Measure from ground to bottom of rail
Add .5 to an 1 "
Using 6x6 and 4x4 make 4 blocks
Now with engine running and Air suspension aired up
Place under rails
Drop air.
Rails come down
Your are done, as you only need to raise the rail a min of .5 inch to remove weight from tires.
If you place something under the tires (Recommended) then allow for that height.
Now you can do the same except perform your measurement with air suspension aired up and subtract .25 to 1 inch.
Add .5 to an 1 "
Place under rails
Drop air.
Rails come down
