mlts22
Jun 20, 2014Explorer II
The wheel package is a wise thing. When at a CG, it might be useful as a way to mark your spot while you are gone, especially if tied down somehow via a steel cable.
As for the hitch lock, I'd probably point to Bolt Locks (it keys to the Travato's door/ignition key), so you have one less key to worry about.
Does it swing out enough so you can open the van door to at least 90 degrees?
38,777 PostsLatest Activity: May 24, 2026
