wincrasher65
Jun 20, 2014Explorer
No, the passenger side door does not swing out 90 degrees - more like 75 to 80. To me that doesn't really matter, as the bathroom blocks that door - you only need to open it to open the driver's side door. It could be held open with a bungee if needed.
I seriously doubt I'd remove it while on the road. It would be very heavy with gear in it - at least too heavy for me to want to remove and then later try and reinstall. I suppose if you wanted to use it to haul stuff you would completely unload, then I guess that would be do-able.
38,777 PostsLatest Activity: May 24, 2026
