Daveinet
Oct 19, 2013Explorer
Check how far the throttle valve opens. It is possible that it is opening beyond vertical. Measure the voltage on the throttle position sensor. Make sure it is still changing throughout the full travel. Voltage will top out at 5 volts. Mixture enrichment happens at 90% throttle. If it is hitting too soon, wide open throttle will not be tuned correctly, because as soon as it hits mixture enrichment, it is no longer in closed loop mode. Don't know if that engine uses MAP, or mass air flow. Speed density (mass air flow) sensors can get dirty and stop working correctly.
38,766 PostsLatest Activity: Jan 10, 2026
