usersmanual
Oct 15, 2016Explorer
holstein13 wrote:
For the past couple of months, I've noticed an annoying problem while refilling the DEF tank at truck stops.
The problem is that I have a 2.5-gallon white jerry can that I use to transport the bulk diesel from the pump to the back and other side of my motorhome. But when I return to the pump to fill the can again, the pump has timed out and makes me re-swipe my fuel / pump start card.
To be clear, I am not putting the nozzle back in place on the hook after filling my 2.5-gallon tank. I pull out the nozzle from the tank and lay it gently on the floor. In the past, this would not cause me a problem. I could refill my tank several times even with the 5 minutes pause between fills.
This occurs at Flying Js and PIlots. Has anyone else noticed this problem? Is there any solution other than to carry two re-fill tanks?
why would you be doing this?
