usersmanual
Oct 16, 2016Explorer
lanerd wrote:usersmanual wrote:Jim Norman wrote:
Our rig has Fuel Fill on both sides. DEF is only on the driver side. I so far, have just bought jugs. I intend to keep one jug in the rig full just in case. better that than running out. I may just refill a jug when filling. Use the can, top off the tank and refill the jug. But I am new at Diesel so maybe I am missing something,
no your not missing anything the OP is because he only has one filler opening which as I have said 3 times is hard to believe but it is what it is so he has to fill on the right but PP fill is on the left
or vice versa
The OP is talking about filling his DEF tank....not his diesel tank. He did mention (in error) that he had to fill the container with "diesel" and take to the other side.....but he really meant fill the container with DEF.
I'm sure he has dual fills for his fuel tanks, but I have never seen dual fills for the DEF tank.
Hope this clears the confusion.
Ron
In my opinion there is no confusion because if he had dual fills then he would(I assume) pull into a diesel fill area that allows him to fill fuel and DEF at the same time? It appears that this is not a viable situation otherwise why would he be complaining about the def system being on the opposite side he fills on pray tell me that?
On edit iam more than totally aware hes talking about filling his def tank
