holstein13
Oct 15, 2016Explorer II
Strange new DEF refill problem
For the past couple of months, I've noticed an annoying problem while refilling the DEF tank at truck stops.
The problem is that I have a 2.5-gallon white jerry can that I use to transport the bulk DEF from the pump to the back and other side of my motorhome. But when I return to the pump to fill the can again, the pump has timed out and makes me re-swipe my fuel / pump start card.
To be clear, I am not putting the nozzle back in place on the hook after filling my 2.5-gallon tank. I pull out the nozzle from the tank and lay it gently on the floor. In the past, this would not cause me a problem. I could refill my tank several times even with the 5 minutes pause between fills.
This occurs at Flying Js and PIlots. Has anyone else noticed this problem? Is there any solution other than to carry two re-fill tanks?
ON EDIT:
It's difficult to understand how awkward my DEF refueling inlet is placed on my coach and I noticed some people asking about it so I've drawn a little diagram to show you exactly how silly it is. As you can see, the diesel fuel inlet is on the driver's side (and there is a second one on the curb side not shown. But the DEF inlet is at the back of the coach on the curb side.
ON EDIT:
