JulieB888's avatar
JulieB888
Strange noises coming from around automotive battery
Hey Folks,
I am having an issue that I am kind of worried about. It would be great to have some input from those knowledgeable about these things.
I have a 1992 Roadtrek, on a dodge ram van. Yesterday after i strated it, I noticed that there was a subtle ring, followed by a click while it was idiling. They both occured in the same order, following thw same intervals. When it began to move these noises continued for a minute and then they went away. I drove for about half hour and then parked. When I started the van later that night I noticed that they were back. I opened the hood and listened. They seemed to be coming from around the automotive battery. Everything under the hood looked and smelled fine. When I got back in the cab, I noticed that the clicking sound was synced with the systematic dimming of the lights inside the coach. This systematic dimiming always happens when the engine is running. The headlights and the dash lights were normal. I turned on the engine 3 more times last night and this whole process would it repeat itself. However when I started the van this morning the noises were gone. I am a bit worried. Should I be?
A few days ago my alternator belt was making a whining noise, when it was very cold and rainy. The noise went away as well. I am not sure if the two are related.
Any and all input would be highly appreciated.
Thanks so much!
Julie
  • Check for a loose connection on the battery or clean the battery connections could be hearing arcing.
  • Is the defroster running? Maybe it's the AC compressor running..?
    That shouldn't dim the lights though unless battery or alternator is weak.
