Golden_HVAC
Apr 04, 2015Explorer
Probably one of the springs or pins inside the door latch broke.
Are you going to be able to latch it and get the RV home or to a repair facility?
I had to change my door lock several years ago (the key can not be changed, so I had to replace the lock) and was able to remove the whole lock assembly, and replace the whole thing. I think the cost was around $250 - $300. The RV supply store had special ordered this lock, and the customer did not pick it up. So they had one in stock, and for a discount, because the first customer lost his deposit on the deal. .. .
You might be able to take it to a locksmith, if it is not to messed up, and have it repaired. Yet many locksmiths are not familiar with the typical RV lock, and might not be able to help out. . .
Good luck,
Fred.
Good luck,
Fred.
38,766 PostsLatest Activity: Jan 10, 2026
