David0725
Apr 05, 2015Explorer II
Ye I did use the drivers door to get in to work on the other door. Its by far the Easiest lock to work on. we did dissemble the lock took it apart from the inside and out side. there was nothing left of it to catch the door hang. the door would open at the top and the bottom but caught in the center we had the frame out bent so we could see everything and we could see even more from the inside. but after prying for 2 hr I took the growbar to it. even then it would budge. so I sais the hack with it. its coming down and finally it popped opened. I will jusy ored a new luck door handle and replace it.
38,766 PostsLatest Activity: Jan 10, 2026
