rgatijnet1
Feb 13, 2017Explorer III
I would suggest that you somehow lift the rear end of the coach, with a wrecker, or whatever, so that you do not drag the belly of the coach across the ground if you just tried to pull the coach out.
A board under the rear levelers MAY work but you also might find that they can raise the coach for leveling but that they are not strong enough to raise the rear wheels off of the ground.
38,778 PostsLatest Activity: Jun 05, 2026
