pianotuna
Sep 21, 2014Nomad III
Hi Dana,
Welcome to the forums!
The 1.5 gallon tank holds 1/2 as much as the 3 gallon, and is quite probably a lot heavier.
You will need something that does LOTS of pressure for class A tires.
P.S. Amazon is your friend.
DanaRuns wrote:
Okay, thanks everyone! Sounds like a compressor is the way to go. I'm not familiar with them. What's the difference between a 1.5 gal and a 3 gal compressor? What's the difference between 4 SCFM @ 40PSI and 2 SCFM at 90PSI? (Comparing the two suggested above).
What do I need to know about compressors?
