RLS7201
Sep 21, 2014Explorer II
DSDP Don wrote:
Dana.....If you feel comfortable filling/checking your own tires, this is a great compressor that many of us use. It's available at Sears and has plenty of pressure to fill your tires.
The air chuck (filler) locks onto your valve stem so you don't have to hold it. It even has a gauge built in that gets you pretty close to your target pressure. You can check with a tire gauge when done.
It runs on 110 volts so you can even use it when camping, just start your generator. It has other attachments for filling things like balls and toys. Lastly, it's compact and fairly light weight (20 lbs) I stick it in an old pillow case and store it in my bay.
Ditto. I have had the same compressor on board for over 10 years. Meets the size, capacity & PSI compromise perfectly.
Richard
