91tiger's avatar
91tiger
Stupid Question on Generators
Just starting to explore moving up from a class B to class C. Do most of the class C generators run off propane or gasoline? Seems like running off of gasoline from the unit's fuel tank would be the way to go. If a unit comes with a propane generator, would it be easy to switch out for a gasoline model of the same size?
The Coachmen Freelander specs say it is a "gas" generator. I assume that is gasoline not LP Gas?
