akrv
May 20, 2018Explorer
The reason for no big diesel is heat and weight. Also if you want a generator it will be propane and you will have trouble keeping enough propane around when you are snow-machining. The V-10 is only a 305hp anything bigger runs to hot. For more speed up a hill you can put aGear Vendors in it. Your torque range on a V-10 is 3500 rpm and over . Good Luck on the hunt.
38,778 PostsLatest Activity: Jun 10, 2026
