Old-Biscuit
Aug 21, 2015Explorer III
YES this is a safety issue!!!!!
You state lower of two high temp so at least you understand that you have 2 different temps of t-stats
Left set of t-stats is for the electric heat element.......it is a 120V AC set with normal temp t-stat and a high temp t-stat.
Normal t-stat is what does ALL the heating control. OPENS when water temp reaches 130*F then when water temp drops below 115*F it CLOSES and allows heating to occur with electric element.
The High temp t-stat is there to shut down heating if normal t-stat FAILS. It is a 'safety' backup measure. It OPENS at 170*F and TRIPS so that no more heating can occur until owner intercedes.
BUY a new 120V AC t-stat set. $25
FYI the other set on right has nothing to do with electric heat function.
It is a 12V DC set for control of propane function. Same set up, same temp set points....Just 12V DC & for propane.
IF either of the High Temp t-stats should FAIL to OPEN (after normal has failed) then the only thing left is the T&P Relief Valve which OPENS (and BLOWS Steam/HOT-HOT water out side of Water Heater OPENS at 210*F/150 PSI
REPLACE THAT 120V AC Set and be safe...water heater although small is a BOILER capable of severe injuries and damage.
On Edit:
Eagles Pride RV is in Titusville
Order it via Internet
Replace it!
Use PROPANE until you replace the electric element set of t-stats
On Edit:
Replace it!
