heyobie
Nov 07, 2016Explorer
When I was underneath the RV checking things out a month ago, I saw some scary grounds on the frame with spade connectors. The connectors and the screws looked bad and I said to self, 'Gotta clean up all the grounds'. But I didn't get to it. Had bigger fish to fry. Engine ran real bad. Changed plugs, wires, cap and rotor. Runs like new. The rotor was rusted on the tip. Gas gauge didn't work. Dropped tank and installed new sender. Mint.
So I needed to get the heat running so I could work on it in fall/winter. I will get to the contacts as suggested. It is working fine on 12.5 volts now. It must have just needed a little more current to get through the bad contact, where ever it is. I will clean it up. Thanks again.
Next project is the Onan generator. I was told it worked until mice chewed some wires. Wish me luck
38,767 PostsLatest Activity: Sep 19, 2016
