dougrainer
Dec 18, 2019Nomad
How long does it take for the Hi Limit to trip? Have you checked the INTAKE from outside to make sure there is no restriction? A partial restriction would cause lack of some air to the burner, but usually this will cause a rich condition and black sooting. I would suspect a bad motor, not running at correct RPM's, but enough to make the sail switch close. With inadequate volume of air, the furnace burner casing will run hotter. The reason I suspect the motor is you stated that until now, the furnace ran correctly even before you attempted the ducting modifications. Doug
38,769 PostsLatest Activity: Mar 31, 2026
