Hi,
Chances are that the thermostat is made by Suburban, or at least might have the Suburban name on the thermostat someplace. The rooftop A/C unit or heat pump probably is not made my Suburban. More likely it is a Coleman, Dometic, or another brand.
The Furnace normally is built by Suburban, and one other furnace manufacture. So I am not surprised by their confusion.
Anyway most RV heat pumps have a thermostat that will shut it off at about 40F outside air temperature, and switch it over to the propane furnaces. This is normally automatic.
Also if you don't have 120 volt power, the furnace will come on right away with any call for heating. If you have only 105 volts, it will still try to run the heat pump, though it is bad on a compressor to run it at below about 104 volts.
Good luck!
Feel free to ask any question. Probably most have been asked at least 10 times over the past 10 years!
Fred.
