dtrink wrote:
When I purchased my 2003 Gulfstream Sun Voyager used the electric part of the hot water heater did not work. I replaced the heating element because the on/off switch was on and I figured the element was probably burned out. It still did not work and was not getting any power to the element. I checked the breaker and it is not tripped. Does anybody have any ideas or should I just start tracing wiring? Thanks.
what I have found on 3 different sub water heaters is the way the thermostat and hot feed to it is jammed in (plastic cover jammed against it) there the stat shorts to ground.Take a meter and see if u have power to stat if so replace stat (note there is two 12v and 120V)
if no power to stat then as other say here say bad switch or switch not turned on in MH but iam assuming surely u know to do that
so I rule out the obvious
