mc_cc
Jun 21, 2016Explorer
A front trac bar will help make the steering less loose feeling when you hit a bump. It will also prevent the dreaded death wobble on those older F53's. This is standard equipment by Ford beginning in 2007. While you are at it, go ahead and get the rear trac bar. While you are installing those, go ahead and do the cheap handling fix too. It does help, but will not completely eliminate the sway from big trucks and wind. I have considered purchasing the beefed up sway bar by Road Master. I wonder if anyone has installed this on their rig?
38,767 PostsLatest Activity: Jan 13, 2022
