Jun 22, 2016Explorer
TNGW1500SE wrote:427435 wrote:NAUTIQUE wrote:kmb1966 wrote:
I have a 2001 Itasca Suncruiser built on a 2000 Ford F53. Just got back from a long trip. Overall it did fine, but am looking for suggestions on what to make it a little easier to drive.
Hey kmb,
Lots of good suggestions above.
Mine's a 2000 GBM on a 1999 F53. These were my steps:
Started with new tires & Bilstien shocks.
Added Steer Safe.
Added Ultratrac rear trac bar from Brazel's.
Did the Cheap Handling Fix.
If I were to do it again, I'd just about reverse the steps.
First I'd get it weighed and make sure tires are good & aired-up correctly. Then I'd do the CHF. Then add a rear trac bar.
The CHF really tightened-up the "side to side: rock and general handling input. Do this first & see how you like it - Great no-cost mod.!
The Rear Trac bar really helped the "tail-wagging-the-dog".
The Steer Safe is a nice extra saftey feature & helped tighten up the steering.
My rig rides pretty nice now (well for a delivery truck chassis! :) )
Those all may be beneficial but, before spending money on add-on's, get it aligned with 4+ degrees of caster. With a good alignment, you may well be satisfied with the handling as I was.
The only problem getting an alignment is finding a place that can do it RIGHT. Many shops say they can but..........
Find a shop that does truck work--------that's what I did. I did have to insist on getting the caster changed when it was at only about 3 degrees.
38,767 PostsLatest Activity: Jan 13, 2022
